Related Products
Top Signal 3-Way Splitter 600–4000 MHz 50 Ohm N-Female TS413101
Features of the Top Signal 3-way 50-ohm splitter One N-female input, three N-female outputs. 600–4000 MHz frequency range. 50 ohm impedance. Attenuates < −4.8 dB. The Top Signal 3-way splitter attenuates −4.8 dB to each antenna. (Click to enlarge.) How the Top Signal 3-way 50-... See More
Buy Now
Top Signal 4-Way Splitter 600–4000 MHz 50 Ohm N-Female TS414101
Features of the Top Signal 4-way 50-ohm splitter One N-female input, four N-female outputs. 600–4000 MHz frequency range. 50 ohm impedance. Attenuates < −6.0 dB. The Top Signal 4-way splitter attenuates −6.0 dB to each antenna. (Click to enlarge.) How the Top Signal 4-way 50-o... See More
Buy Now
Top Signal 2-Way Splitter 600–4000 MHz 50 Ohm N-Female TS412101
Features of the Top Signal 2-way 50-ohm splitter One N-female input, two N-female outputs. 600–4000 MHz frequency range. 50 ohm impedance. Attenuates < −3.0 dB. The Top Signal 2-way splitter attenuates −3.0 dB to each antenna. (Click to enlarge.) How the Top Signal 2-way 50-oh... See More
Buy Now
Wilson 2-Way Splitter 50 Ohm N-Female 859957
This item has been discontinued. Please see our splitters page for alternatives. Features of the Wilson 2‑way 50‑ohm splitter One N‑female input, two N‑female outputs. 700–2700 MHz frequency range. 50 ohm impedance. Attenuates −3.0 dB. How the Wilson 85997 2‑way 50‑ohm antenna splitter is used Split... See More
Buy Now
Wilson 2-Way Splitter 75 Ohm F-Female 850034
Features of the Wilson 2‑way 75‑ohm splitter One F‑female input, two F‑female outputs. 700–2700 MHz frequency range. 75 ohm impedance. Attenuates −3.0 dB. How the Wilson 2‑way 75‑ohm splitter is used Splits a single run of coax cable equally into two separate runs to indoor antennas. For in-building... See More
Buy Now
