Related Products
Top Signal TS-195 Coax 5 ft. N-Male/SMA-Male Connectors TS333005
Features of Top Signal TS-195 coax cable LMR®-195 equivalent coax cable. 5′ length. Terminated at one end with an N‑male connector, at the other with an SMA‑male connector. 50 ohm impedance. Attenuates −0.46 dB @ 800 MHz/−0.80 dB @ 1900 MHz. LMR® is a registered trademark of Time... See More
Buy Now
Top Signal TS-195 Coax 10 ft. N-Male/SMA-Male Connectors TS333010
Features of Top Signal TS-195 coax cable LMR®-195 equivalent coax cable. 10′ length. Terminated at one end with an N‑male connector, at the other with an SMA‑male connector. 50 ohm impedance. Attenuates −0.91 dB @ 800 MHz/−1.60 dB @ 1900 MHz. LMR® is a registered trademark of Tim... See More
Buy Now
Top Signal TS-195 Coax 15 ft. N-Male/SMA-Male Connectors TS333015
Features of Top Signal TS-195 coax cable LMR®-195 equivalent coax cable. 15′ length. Terminated at one end with an N‑male connector, at the other with an SMA‑male connector. 50 ohm impedance. Attenuates −1.37 dB @ 800 MHz/−2.41 dB @ 1900 MHz. LMR® is a registered trademark of Tim... See More
Buy Now
Top Signal TS-195 Coax 20 ft. N-Male/SMA-Male Connectors TS333020
Features of Top Signal TS-195 coax cable LMR®-195 equivalent coax cable. 20′ length. Terminated at one end with an N‑male connector, at the other with an SMA‑male connector. 50 ohm impedance. Attenuates −1.78 dB @ 800 MHz/−2.89 dB @ 1900 MHz. LMR® is a registered trademark of Tim... See More
Buy Now
Top Signal RG58 Coax 20 ft. N-Male/SMA-Male Connectors TS380020
Features of Top Signal RG58 coax cable RG58 coax cable. Solid PE dielectric. 20′ length. Terminated at one end with an N-male connector, at the other with an SMA-male connector. 50 ohm impedance. Attenuates −2.74 dB @ 800 MHz/−4.83 dB @ 1900 MHz. How Top Signal RG58 coax cable works Connec... See More
Buy Now
