Related Products
Wilson Ceiling-Mounted Omni Cellular Dome Antenna 698–2700 MHz F-Female 304419
Features of the Wilson dome antenna Works with 698–2700 MHz 5G and 4G/LTE frequencies. (Learn more about 5G compatibility.) 3.3″ × 7.3″ × 7.3″ omnidirectional building antenna. Mounts to drywall ceiling or other drillable, horizontal surface no thicker than 1.5 inches (mounting nut in... See More
Buy Now
SureCall Low-Profile Ceiling-Mount Cellular Dome Antenna 617–2700 MHz N-Female SC-528W
Features of the SureCall low‑profile dome antenna 12.2″ × 12.2″ × 2.11″ omnidirectional building antenna. Works with 617–2700 MHz 5G and 4G/LTE frequencies. (Learn more about 5G compatibility.) Two mounting options: If you have above-ceiling access, use the threaded mounting nut. If y... See More
Buy Now
Top Signal EDGE 5G Dual-Mount Dome Antenna 600–4000 MHz N-Female TS250620
Top Signal EDGE is a new series of in-building cellular antennas with a modern design and with custom features for easier mounting and positioning. The EDGE panel antenna and EDGE dome antenna have similar designs, giving the antennas in your building or home a consistent look when they are used tog... See More
Buy Now
Top Signal EDGE 5G Flex-Mount Panel Antenna 600–4000 MHz N-Female TS260820
Top Signal EDGE is a new series of in-building cellular antennas with a modern design and with custom features for easier mounting and positioning. The EDGE dome antenna and EDGE panel antenna have similar designs, giving the antennas in your building or home a consistent look when they are used tog... See More
Buy Now
Wilson Low-Profile 4G/LTE Cellular Dome Antenna 608–2700 MHz N-Female 314407
Features of the Wilson low-profile dome antenna Works with 608–2700 MHz 5G and 4G/LTE frequencies. (Learn more about 5G compatibility.) 9.4 × 9.4 × 0.33‑inch omnidirectional indoor building antenna. Mounts to drywall ceiling or other drillable, horizontal surface no thicker than 1.5 i... See More
Buy Now
