Related Products
LTE 38-Inch Vehicle Antenna RFI Quick-Release Whip 6.5 dBi 698–2700 MHz TS210701
This antenna has been replaced by the RFI 5G 38-inch quick release antenna. Features of the RFI quick‑release whip antenna 4.5–6.5 dBi nominal gain. 38.2″ (90.7 cm) tall × 1.22″ (3.1 cm) wide at the base. Black fiberglass radome. RFI’s patented Meander™ radiating elements deliver extr... See More
Buy Now
LTE Vehicle 26-Inch RFI Whip Antenna 5.5 dBi 698–2700 MHz TS210513
Features of the 26″ RFI whip antenna 4.5–5.5 dBi nominal gain. 25.8″ (65.5 cm) tall × 1.0″ (2.6 cm) wide at the base. Black fiberglass enclosure. RFI’s patented Meander™ radiating elements deliver extraordinary consistency in gain, coverage pattern, and bandwidth. Works with 698–2700&... See More
Buy Now
LTE 29-Inch Vehicle Antenna RFI Quick-Release Whip 5.5 dBi 698–2700 MHz TS210511
This antenna has been discontinued. Please see our other RFI antennas for vehicles. Features of the RFI quick‑release whip antenna 4.5–5.5 dBi nominal gain. 28.9″ (73.5 cm) tall × 1.22″ (3.1 cm) wide at the base. Black fiberglass radome. RFI’s patented Meander™ radiating elements... See More
Buy Now
LTE 38-Inch Marine Quick-Release Antenna RFI Whip 6.5 dBi 698–2700 MHz with Ferrule & Cable TS210702
Features of the RFI quick-release whip antenna 4.5–6.5 dBi nominal gain. (Learn more about optimal gain for marine antennas.) 38.2″ (90.7 cm) tall × 1.22″ (3.1 cm) wide at the base. White fiberglass enclosure. RFI’s patented Meander™ radiating elements deliver extraordinary consistenc... See More
Buy Now
LTE 82-Inch Marine Quick-Release Antenna RFI Whip 8.5 dBi 698–2700 MHz with Ferrule & Cable TS210902
Features of the RFI quick-release whip antenna 4.5–8.5 dBi nominal gain. (Learn more about optimal gain for marine antennas.) 81.89″ (208.0 cm) tall × 1.22″ (3.1 cm) wide at the base. White fiberglass enclosure. RFI’s patented Meander™ radiating elements deliver extraordinary consiste... See More
Buy Now
